TImode versus Xcas mode
compsystems
What is the difference of TImode (89/92) versus Xcas mode?
I only notice that the output of the solvers are algebraic expressions and not lists of solutions
Xcas mode
1: solve([ y = x^2, y = 2*x + 3 ],[x,y]) [enter] returns
[[3,9],[-1,1]]
TImode (89/92)
(x=3) and (y=9)) or ((x=-1) and (y=1)
Xcas mode
[[3,9],[-1,1]]
TImode (89/92)
Re: TImode versus Xcas mode
Indices start at 1, the parser also accepts some ti syntaxes that are not accepted otherwise (for programming).
compsystems
ok
Within a program with which command to set these modes?
cmd(tiMode/xcasMode)
xcas_mode(0) (default) or xcas_mode(3) (TI)
compsystems
Ideas
To be able to restore the configuration mode for sotfware and not by hand, please add the option xcas_mode(-1), as it does autosimplify(-1)
xcas_mode(-1) [enter] returns current xcasmode [0 or 1 or 2 or 3]
And when exe xcas_mode(0 or 1 or 2 or 3) , returns the keyword Done as alias of 1, and not 1 because is the output associated with the mode 1=Maple
samples:
1:
xcas_mode(0) [enter] returns
"Warning: some commands like subs might change arguments order"
Done
2:
xcasModeFlag:=xcas_mode(-1) [enter] returns
0
3:
xcas_mode(3) [enter] returns
Done
4:
xcas_mode(xcasModeFlag) // restore the previous xcas mode
samples:
1:
Done
2:
0
3:
Done
4:
Dernière modification par compsystems le mer. août 09, 2017 8:30 pm, modifié 1 fois.
xcas_mode() returns the current mode, you can save yourself the current mode before changing it, then you can restore it later.
compsystems
ok
The output of xcas_mode (#) is currently a string of text, I think it is better to return a confirmation output of change 1 or Done and the warning message in between the cmd and output
compsystems
related
That returns autosimplify() and autosimplify(-1)?
case 1:
autosimplify(0) -> 1
autosimplify() -> 1
autosimplify(-1) -> 'Nop'
case 2:
autosimplify(1) -> 1
autosimplify() -> 1
autosimplify(-1) -> 'regroup'
case 3:
autosimplify(2) -> 1
autosimplify() -> 1
autosimplify(-1) -> 'simplify'
case 4:
autosimplify(3) -> 'simplify'
autosimplify() -> 1
case 1:
autosimplify() -> 1
case 2:
autosimplify() -> 1
case 3:
autosimplify() -> 1
case 4:
autosimplify() -> 1
I will modify autosimplify() to return the command used.
compsystems
thanksparisse a écrit :I will modify autosimplify() to return the command used.
Input
(string, explicit input)
autosimplify('Nop' / 'regroup' / 'simplify' ) -> Done
(numeric input)
autosimplify(0 / 1 / 2 ) -> Done
output
autosimplify() -> 0 / 1 / 2 (numeric output)
autosimplify(-1) -> 'Nop' / 'regroup' / 'simplify' (string, explicit output)
same for xcas_mode()
Input
(numeric input)
xcas_mode(1 / 0 ) -> Done
output
xcas_mode() -> 0 / 1 / 2 / 3 (numeric output)
xcas_mode(-1) -> 'Xcas' / 'Maple' / 'Mupad' / 'TI' (string, explicit output)
Dernière modification par compsystems le ven. août 11, 2017 7:03 pm, modifié 1 fois.
compsystems
Hi, Bernard.
I think I've already mentioned it, I'm doing an educational research project with CAS, and I'm using Xcas for the experiment, my intention in some improvements or aesthetic changes, is for the purpose of favoring or facilitating the use in the interface especially of Undergraduate students, for this reason my suggestions
The arguments 0/1/2 are not very explicit, I see that the command autosimplify accepts numerical arguments as symbolic, the complex_mode command only accepts 'complex' please add 'Nop' as arg
Thanks
Thanks
I don't understand what complex_mode('Nop') would mean. Moreover, students will certainly change complex mode with the interface, not with a command, unless they are sufficiently advanced to understand how to do it properly.
