giacpy-0.6.2/setup.py file reports this text:
#If you have QT support, you can enable qcas with --enable-qcas
# But to use qcas you should create first: qcas/libqcas.a with:
# qmake libqcas.pro ;make
import sys
if "--enable-qcas" in sys.argv:
USE_QCAS=True
sys.argv.remove("--enable-qcas")
else:
USE_QCAS=False
#######################################Does giacpy really need libqcas.a library for supporting QCAS?
